DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 09-18-2009, 01:42 PM
mjs182004's Avatar
mjs182004 mjs182004 is offline
Vehicle: 2008 Hyundai Tiburon
Send a message via AIM to mjs182004 Send a message via Skype™ to mjs182004
Yes that diagram is correct.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
08 Hyundai Tiburon, also a 91 Cadillac Brougham d'Elegance===> http://www.cardomain.com/id/mjs182004
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-01-2009, 02:16 PM
Franklinnn's Avatar
Franklinnn Franklinnn is offline
Vehicle: 2005 CE neon
for those who have add any stereo (or anything else electrical);
Where is the best place to put the power to the battery for a wiring kit for a amp+sub?
Where is the best place to ground the amp wiring for the trunk? Under driver seat?
Where is the best place to ground the stereo ground wire?
Old 10-01-2009, 06:25 PM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
1. I wired it up to the battery with an inline fuse. I think that's what you are asking?
2. I removed the rear seat (very easy and quick to remove and reinstall) and grounded it under there. Just run the ground wire under the rear seat frame/bracket, whichever you'd like to call it.
3. The same place the factory stereo is grounded. Just hook up the wires. If not, you'll have to crawl under there and find a metal spot.
__________________
Old 10-02-2009, 01:42 AM
Franklinnn's Avatar
Quote:
Kinda, i have (or its on its way) the whole wiring kit, but was more importly wondering how you hooked the power cord itself to the battery.
In my old corolla i just kinda jammed it in where i could, and was trying to make sure i do a neat and clean job.
also is there any area to run the power cord, or will i have to drill one?
I may be able to answer these myself, but i have not crawled or looked around the car for the stereo quite yet, but thanks for your patience!!!
Old 10-02-2009, 01:58 AM
darthroush's Avatar
Not to sound too smart (hint - dip****5000), but I used a ring terminal and bolted it down to the battery terminal bolt. I believe my kit actually came with it. If yours doesn't, they are not expensive by any means. I ran the power wire through the harness grommet in the firewall and then under the carpet the whole way to the trunk. The easiest way to get it through that grommet is to run a coat hanger or something similar through the grommet first, attach the power wire to it and then just pull it through.
__________________
Old 10-02-2009, 02:16 AM
Franklinnn's Avatar
thanks! ill maybe post pictures as i go, in case anyone else comes around with the same questions i have.
help eliminate the need for reposting and reposting the same stuff over and over for idio... advanced car audio (or anything too in depth) persons.
also did you run the power around the same area as the RCA? some cords are more prone to pick up bad noise and others dont, have you run into problems, or did you make sure they were not too close? or is this some old wifes tale?
Old 10-02-2009, 02:14 PM
darthroush's Avatar
I ran each wire down separate sides of the car just to be safe. I didn't want to find out if that was true or not after I put everything back together. When they are hooked up to the amp, they are only a couple of inches apart anyways...
__________________
Old 10-02-2009, 04:02 PM
Captansavaho Captansavaho is offline
Vehicle: 98 dodge neon
Send a message via AIM to Captansavaho
if you run them down the same side they will pick up interference trust me had to rewire my whole system..and i ground my amp to the strut tower in the back..but know my amps are under my driver and passenger seats..plenty of spots to ground them towards the center console
__________________
12.5:1 compression n/a engine SOLD!
Car is still for sale!
Old 10-02-2009, 11:45 PM
mjs182004's Avatar
you guys are giving some good info. this is what i like to see on a car forum!
__________________
Old 10-03-2009, 03:48 AM
Franklinnn's Avatar
i feed proud for asking such good questions then
i should have all the equipment by Tuesday and do it all then!
any links to removing the whole front (head?) unit?
The aux imput is on the back, so im just going to run it right into the compartment below it for my Ipod, so will need to drill a hole there and run and connect wires then BAM!!!
Tags
back, dodge, installation, neon, stereo, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
