AC
Old 05-25-2010, 05:54 PM
Vericosa's Avatar
Vericosa
Vericosa is offline
Default AC
my ac works a bit then it freezes up and gets wet just left of the glove box anyone have a clue why its doing this seems to work great till its real hot outside
Old 05-25-2010, 06:43 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Is it low on the refrigerant? I don't know much about A/C systems...just a thought.
Old 05-25-2010, 07:27 PM
Moparkyle's Avatar
Moparkyle
Moparkyle is offline
It's kind of a common neon thing those things sweat like *****
Old 05-25-2010, 07:49 PM
Vericosa's Avatar
Vericosa
Vericosa is offline
I was going to check that and when it freezes it wont even blow vent air
Old 05-25-2010, 08:38 PM
garrett123's Avatar
garrett123
garrett123 is offline
Clogged drainhose?
Old 05-26-2010, 01:29 AM
BroodRed's Avatar
BroodRed
BroodRed is offline
My SXT does the same thing. The AC seems to freeze up, then not blow any air...
Old 05-26-2010, 01:49 PM
Vericosa's Avatar
Vericosa
Vericosa is offline
where about is drain hose and mine is an sxt as well I just know soon its going to be retarded hot in my part of Texas soon
Old 05-27-2010, 01:23 PM
NeonOn19s's Avatar
NeonOn19s
NeonOn19s is offline
You don't need AC in Texas.... Just roll down a window.. LOL
The drain should be on the bottom with a angle toward the firewall where it drains if I'm correct. But then again I don't use my AC here in Texas.. well with this car at least.
Old 05-28-2010, 10:12 AM
houndog97's Avatar
houndog97
houndog97 is offline
If you mean it stops blowing I would think it's the blower motor going bad. I've had alot of problems with this neon but I have to admit the ac is the coldest I ever owned in a car and this is great because I'm in south fla !
Old 05-29-2010, 12:35 PM
Vericosa's Avatar
Vericosa
Vericosa is offline
Your hardcore man Spring is way more humid then New Braunfels I need my ac haha. My ac works fine for awhile then it wont blow, this only happens in the summer too its fine when its about 75 to 80 outside once it has to work it craps out on me
