Engine Light On and Off - Car Chugging/Sluggish On and Off
Old 08-25-2010, 07:30 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Once it does it, stop and pull them from the cluster. When the light goes on and off, that means it is an intermittent problem. In your case, it's pretty obvious though.
Old 08-25-2010, 08:42 PM
showsxt's Avatar
showsxt
showsxt is offline
exactually what happened to mine the light came on and than went off. Actually mine was the wiring to the tranny and the camshaft sensor. The wiring just made the plugs and wires and camshaft sensor all go bad. Hopefully yours is what went wrong with mine. Did not cost much seeing we did it our selves. I think like 300 bucks for everything even the alternator went bad.
Old 08-31-2010, 09:53 AM
DobermanDodge's Avatar
DobermanDodge
DobermanDodge is offline
ALRIGHT!!! **** UPDATE ****
Start my car this morning and the engine light is back! Did the thing and the codes are;
P 0301 AND P 0340
Any one have any idea what these mean? How do I find out what these codes mean?
Old 08-31-2010, 10:34 AM
darthroush's Avatar
darthroush
Section Moderator
P0301 is a misfire in cylinder 1. P0340 is the camshaft position sensor circuit.
Old 08-31-2010, 05:20 PM
showsxt's Avatar
showsxt
showsxt is offline
I knew it same problem as mine if you fix the camshaft sensor I am pretty sure both codes will go away and your ride will be better than ever. Besure to check the wiring to the camshaft sensor goes bad sometimes like mine did.
Old 09-01-2010, 01:19 AM
darthroush's Avatar
darthroush
Section Moderator
You need to check everything. It is something in the entire circuit, not necessarily just the sensor.
Old 09-01-2010, 08:42 PM
showsxt's Avatar
showsxt
showsxt is offline
Thats what it said and mine was the sensor and the wiring most of the time thats what it ends up being.
Old 09-01-2010, 08:49 PM
darthroush's Avatar
darthroush
Section Moderator
Old 09-01-2010, 09:13 PM
showsxt's Avatar
showsxt
showsxt is offline
Could also be the crankshaft sensor also sometimes shows up camshaft but really the crackshaft.
Old 09-03-2010, 09:33 PM
dizzydessi's Avatar
dizzydessi
dizzydessi is offline
I am having the same problem with my 2003 stratus. The mechanic has had it for 3 weeks and still can not figure it out. The code that it is reading out is p0344 but when the mechanic had it he replaced the crankshaft sensor and cam shaft sensor cheked all the electrical line between there and the computer and even replaced the computer but I can still not accelarate my car past 2500 rpms. I have the car in my backyard again and really need it to run please help!!!
Quick Reply: Engine Light On and Off - Car Chugging/Sluggish On and Off
