Crankshaft sensor location.
Old 04-11-2011, 11:57 PM
blackneonsxt's Avatar
blackneonsxt
blackneonsxt is offline
Default Crankshaft sensor location.
I own a 2003 neon SXT and have been wondering and looking to changing the crankshaft sensor on it. i recently replaced the camshaft position sensor but now its kicking code 0344. was told its probably the crankshaft sensor. its not located by the oil filter like mentioned on some websites. wondering where else it will be? thanks
Old 04-12-2011, 01:09 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Should be under the starter/intake manifold. Don't know why it would be by the oil filter...
Old 04-12-2011, 04:54 PM
blackneonsxt
ok so i found the crankshaft sensor and replaced it along with the camshaft sensor too. but the car is still kicking code 0344..? wiring needs to be checked?
Old 04-12-2011, 05:59 PM
darthroush's Avatar
darthroush
Section Moderator
Wouldn't be a bad idea.
Quick Reply: Crankshaft sensor location.
