2000 dodge neon overcooling - DodgeForum.com
Old 03-20-2013, 02:02 PM
Andrzej1991
Andrzej1991 is offline
Default 2000 dodge neon overcooling
I have a 2000 dodge neon es. I have recently rebuild the cylinder head due to a low compressed cylinder 3. While having the cylinder head off, I replaced the radiator, water pump, thermostat, all seals and gaskets, belts and other parts. After putting everything back together, i drove the car on the highway for 6 hours, the whole time my temp gauge would read cold... When i pulled over, the engine temp increased to operating temperature. My first thought was the thermostat was stuck open. So i drained the coolant and took out the thermostat, and infact it was stuck open. I replaced it with a new one. 4 days later i was having the same problem but the temperature wasnt all the way down, just a line above cold. It takes it long to warm up, any idea???
Old 03-20-2013, 02:38 PM
TejasMtnBiker
TejasMtnBiker is offline
Is the spring side of the thermostat facing the eng block? Also if you have a lot of air in the coolant system it will act weird. But it had to have gotten over 180 or what ever is stamped on the thermostat for it to lock the safety open.... I for one don't like the locking thermostats, even though they are fail safe when it comes to saving your eng.
Old 03-21-2013, 10:08 PM
Moparkyle
Moparkyle is offline
Quote:
If the t-stat was installed backwards it would overheat very fast.
My guess is either air or you bought another faulty t-stat.
If the top hose is cold and the bottom hose is hot, then you need another t-stat.
Old 03-24-2013, 03:00 PM
Andrzej1991
i drained the coolant. took out the t-stat and flushed the whole system. when i took the t-stat it was not stuck open so it functions. i put everything back and filled it up to spec. let it run with cap off to bleed the system of air. it still does not function right. it gets to operating temp when im idling, but once im moving the temp goes down halfway between 0 and operating temp.
Old 03-24-2013, 11:35 PM
Moparkyle
So you're saying it runs between cold and the first dash on the temp gauge?
Related Topics
Thread
Forum
Replies
Last Post
V_pecak
Dodge Stratus
1
07-18-2015 11:43 AM
Hemibuck
3rd Gen Durango
3
07-07-2015 11:51 AM
carid
Vendor Group And Special Buys
0
07-07-2015 08:38 AM
barrd70
2nd Gen Dakota
0
07-05-2015 02:23 PM
arty278
New Member Area
1
07-03-2015 03:07 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
