Dodge neon front end noises
I have a dodge neon 2003. The noise comes from both front sides when i go through uneven roads o rough paths. It sounds like metal to metal clanking. I've had this noise for a while now, my mechanic said it was the plate bushings. So I replaced them and it worked for a while, like a week passed from the repair and I started to hear the same sound as before. I have replaced inner/outer tie rods on both driver and passenger side, and as I mentioned before, I replaced the Lower control arm bushings on both sides. The shocks are still holding on so I don't think that's the problem. Also when I'm parked I rock the steering side to side rapidly and a clanking noise comes from the steering or rack and pinion, I don't know. I already changed the sway bar bolts. Forgot to say that
So my question is, what may be causing this?
Please help!
Please help!
My 00 is having the same problem. I replaced control arms, struts w/new springs, sway bar bushings, all 4 motor mounts. It still squeaks when I push down on the front or go over bumps. One thing I found it that most parts I changed are aftermarket china. Rubber parts are hard compared to OEM and crack faster.
