Low Fuel Pressure
Low Fuel Pressure
Hi all, I have a problem with my wife's Neon ('03 SXT). Started having hard starts so I checked fuel pressure at rail and got ~42 psi (spec is 58 psi). Fuel pressure immediately goes to 0 (zero) once ignition is turned off. Checked fuel pump relay and all is well. Replaced fuel pressure regulator and the problem persists. Any ideas short of replacing the fuel pump? Thanks!
