Noise while coasting from front wheels not a bearing
I have a 2003 Neon SXT that is making a fairly loud noise coming from the front, it sounds like the drivers tire area. It only occurs when coasting, accelerating stops it, as does turning right. Neutral doesn't change it.
We replaced the wheel bearing and the noise is still there. Our next thought would be CV Joint, but I'd rather not spend money replacing another part that isn't bad.
Ideas? I saw in one of the sticky threads that it could possibly be the strut, but it doesn't really sound like suspension, it's more of a grinding that matches the speed of the coasting.
Any ideas would be appreciated. Thanks.
EDIT: SOLVED
Upon inspection of the passenger side, the CV Joint came apart, we replaced the passenger CV Joint and the noise is now gone.
EDIT: SOLVED
Ok here's more weird stuff. We ran the car on jack stands and it doesn't make the noise. We moved the stands from under the frame to under the A arms so there was simulated pressure on the cv joints and still no noise. My dad said he has the speedometer up to 25+ and let off and it wouldn't do it. On the ground you hear it pretty loud at 25.
If it were the tires in need of rotation wouldn't you hear it all the time and not just coasting? He might try rotating them just to rule it out regardless.
The CV boots are all untorn and the one he checked was packed full of grease still.
