HELP NEON 2005 Check Engine
Old 10-28-2013, 04:18 PM
abbas1907's Avatar
abbas1907
abbas1907 is offline
Default HELP NEON 2005 Check Engine
I just changed my thermostat in my 2005 neon sxt and after about 300 miles the check engine light came on for the thermostat/ low coolant level. Coolant is proper and thermostat is new car is not over heating and oil is clean. the car still runs great just hear bubbling when i shut it off. What could be wrong and any solutions?
Old 10-29-2013, 12:08 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
How's the gasket on the radiator cap?
Old 10-29-2013, 02:58 PM
frankarnone70's Avatar
frankarnone70
frankarnone70 is offline
Air in the system . Did u burp it? Thermostat in the correct 1 o' clock posision?
Old 11-06-2013, 03:46 PM
abbas1907's Avatar
abbas1907
The gasket is fine even changed the radiator cap, and i tried burping the system but still nothing. Think it could be a bad coolant temperature sensor?
Old 11-06-2013, 03:48 PM
abbas1907's Avatar
abbas1907
oh and i changed the oil and no coolant was found in the oil as well as no oil in the coolant tank
Quick Reply: HELP NEON 2005 Check Engine
