2000 neon bad bearing in pulley
2000 Neon
I also have a 00 neon with 178K miles. I hear the tensioner pulley goes out often. You could remove the alternator belt and run the car just long enough to confirm or eliminate it. The serpentine belt has the tensioner pulley, A/C compressor, and power steering pump. You might try removing the belt and spinning each pulley checking for noise or play in the pulley bearings.
Do make sure your belts are in good shape and taunt before trying to isolate the noise.
