fuel injector issues - 2001
Old 11-06-2013, 09:42 AM
decrepid's Avatar
decrepid
decrepid is offline
Default fuel injector issues - 2001
I have a 2001 Dodge Neon, 2.0l. Check engine light with a cylinder 1 misfire and cylinder 1 injector error code. I replaced the #1 injector, spark plugs,spark plug wires, and ignition coil. She is running slightly better, but still misfires frequently (ie every time i run her), particularly at idle and low throttle. Fuel pressure at the injector rail is a bit low - 49 - 50 psi. Is fuel pressure ~4 psi below manufacturer specs enough to suggest a fuel filter/pressure regulator replacement?
Old 11-09-2013, 01:57 AM
sbhawaiian's Avatar
sbhawaiian
sbhawaiian is offline
Did you clean all 4 injectors? It looks like you covered everything....
Quick Reply: fuel injector issues - 2001
