Lights dim/flicker
Lights dim/flicker
Hello,
I finally replaced the factory battery today (10+ years old). While changing the battery, I used a battery terminal cleaner and some anti corrosion spray. I was out driving tonight and my lights (headlights, interior, dash etc.) seem to dim/flicker while driving. I assume it's because I'm hitting little bumps. I've made sure the battery terminals are tight, but that doesn't seem to solve the problem and I don't want to over tighten them... I've lifted the hook and tried moving the wires around and that doesn't seem to do anything... Does anyone have any ideas on what to check?
Mine has started doing this after I replaced the battery. I haven't replaced anything on the charging system except battery, but since the engine threw a rod bearing, it's on my todo list.
I suspect it's the alternator, pcm or poor grounding, check your grounds!
If it is the pcm I might crack one open and check for bad capacitors.
