04 Neon brake issues
Hey guys. I'm absolutely stumped. My friend's stepsister needed the brakes on her 04 Neon.
I take the front/left wheel off. I see the pads are practically brand new. We pop the hood to see that her and her boyfriend let the brake reservoir go dry (obviously leaking somewhere).
We fill the reservoir and attempt to bleed the brakes only to sheer the bleeder screw. This little bastard was WRENCHED on. I mean someone had to have been hanging from it. I broke a professional easy out trying to get the remainder out.
Ended up getting it removed and ordered OEM bleeder screws. Tonight I installed the new bleeder screw (still front/left) and it felt great. Tightened it up, topped the fluid, and attempted bleeding it again. Even tight... The bleeder screw was spitting fluid. Tightened it even more and the pedal gained pressure again.
Test drove... No pressure at all. Leaking fluid from the bleeder screw. We're afraid the other screws will be the same way.
Now if the girl and her boyfriend left it dry enough, could it have ruined the calipers? We're ready to order new (reman) calipers from Rockauto, but don't want to waste our time if they do the same.
Any ideas? I'm at a loss. Thanks in advance!
I broke the bleeder screw and easy out trying to do the same thing on my f150 instead of my neon. I have a feeling that when they did the bleeder screws the last time they messed it up or crossed threaded it. They may have even put some kind of epoxy to fix it. I did ending up getting a new caliper. Since they have new bleeders and are bench tested I'm pretty sure they should be okay.
