2004 SXT AC not working...
I have a 2004 Neon STX with a 2.0. 102K miles. Recently purchased this car and wanted to do the regular maintenance before I started driving it. I replaced the motor mounts, timing belt, water pump, idler pully, A/C belt, Alternator belt, O2 sensors, spark plugs, ignition wires and oil pan gasket.
Before I started the work, the AC worked and blew cold air. Now I turn it on and the clutch is not engaging. I tested the power to the compressor and I am not getting any power. I checked the fuse boxes and the fuses seem to be fine. What could I have done to cause this to not be getting power? Is there a relay somewhere I am missing? Does anyone have a wiring diagram for the AC system so I can route to the problem?
Any help would be greatly appreciated.
Thank you for the reply, I did notice the green connector was plugged in but it could be pulled on and off because the tab that secures it was broken off. But it still stayed in place. I still can't figure why I do not have power to that plug or the other that engages the clutch when I turn the ac on in the cab. Any suggestions from past experience or have you read about this with others? I can't seem to find anything on here or other sites.
The funny thing about these AC systems is that you can't read ANY data except for "request" in the PCM. The PCM will not send power unless the low and high side data (actually hidden data) is received. It a frustrating system. Those terminals may be spread OR the wires are broken under the insulation, which I see a lot of.
Get an "Evacuate and Recharge" done, sure. If the plug terminals are bad, here's the repair kit
Mopar Package #: 05083217AA
