2000 a/c
Old 07-07-2014, 01:24 PM
fair67's Avatar
fair67
fair67 is offline
Default 2000 a/c
I have a 2000 neon se and the A/C will work for about 2 weeks so I figure it is a leak somewhere. I was wondering if there happens to be a common place they may leak at so I at least got a starting point to find it. Any help or Ideas appreciated. When it is charged it works great.
Thanks
Old 07-09-2014, 01:30 PM
sbhawaiian's Avatar
sbhawaiian
sbhawaiian is offline
I have a 2000 and for the most part my a/c works pretty good. You can put A134 with a color or black light dye to find the leak. Just hope that there is no leak in the evaporator under your dash.
Old 07-11-2014, 08:48 AM
fair67's Avatar
fair67
fair67 is offline
Thank you very much.
Old 07-14-2014, 01:02 PM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
a good spot to check is that flexible line right at the dryer behind passenger headlight, sometimes the belt can rub that one.
Old 07-14-2014, 03:23 PM
73novass's Avatar
73novass
73novass is offline
its a waste of time to ask where it is a common place just get a can of 134a with leak detector and you will find out real soon. First off does your compressor turn on?
Old 07-15-2014, 11:12 PM
fair67's Avatar
fair67
fair67 is offline
Thank you I appreciate it I will look there for sure.
Old 07-15-2014, 11:14 PM
fair67's Avatar
fair67
fair67 is offline
I just hoped there may be a commen problem. WHen I put 134 in it works perfectly for about a week then no more cold air. Everything works great except for when it leaks out. Thank you
Old 07-16-2014, 12:28 PM
sbhawaiian's Avatar
sbhawaiian
Old 07-17-2014, 02:42 PM
fair67's Avatar
fair67
fair67 is offline
Originally Posted by sbhawaiian
The condenser and evaporator are the two hardest places to find leaks when using dyes. I wonder if this would be an option for you?
Amazon.com: IMAGEŽ Portable AC Refrigerant Leak Halogen Gas Leakage Detector with Storage Case: Home Improvement
Thank you for the good idea I have a buddy who may have one I can use.
Quick Reply: 2000 a/c
