Is my transmission blown?
Old 09-22-2014, 08:18 PM
spudsy's Avatar
spudsy
spudsy is offline
Default Is my transmission blown?
I bought a 2001 Neon with a blown engine. As I was trying to remove the engine I noticed that while the vehicle is in park I can spin the axles and like an old school rear wheel drive the other side spins the same direction like a posi would. Now Iam old school rear wheel and if its in gear things wont turn if in park but this is turning while in park. So is this normal to be able to turn while in park or is the transmission blown up??
Old 09-22-2014, 09:34 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
If the wheels are off the ground they will move independently.
Old 09-22-2014, 09:56 PM
spudsy's Avatar
spudsy
spudsy is offline
Okay so even if the transmission is in park the wheels will still rotate as long as the 2 tires are in the air?
Old 09-22-2014, 10:05 PM
TNtech's Avatar
TNtech
TNtech is offline
Yes, not super easy freewheeling but yes they will turn. In park, the diff case is locked but the diff gears can still move. When the wheels are on the ground they "oppose" each other.
Also, if you disconnect one half shaft the car will roll in park on the ground
Old 09-23-2014, 12:14 AM
spudsy's Avatar
spudsy
spudsy is offline
Okay they turn easy and instead of one going one way and the other going another they turn in the same direction as each other like a locker unit would do like a spooled diff instead of a limited slip style.
Quick Reply: Is my transmission blown?
