2002 Neon SE with 2005 Transmission How to replace TCM
Dealership diagnosed bad TCM as did All Automatic trans shop. I do not have 1,200.00 this is gonna be the 2nd trans after 2 failed rebuilds by an ex dodge mechanic tried to rebuil my 2002 trans. I don't know about compatibility I trusted my mechanic. Took him 1 1/2 years to do it. I finally got car back 2 years ago and now this. I have had bad luck with cars my whole life I love this car was the last thing my mom bought for me week before she died.No other problems EXCEPT I work in a laundromat and she shocks the crud out of me every time I touch driver's side door, it hurts a lot but when tranny failed and drove in limp-in mode no shocking could this be a ground problem causing Electro Static Discharge causing TCM failure? Also recently put new radiator in her and need a new egnition for it as well.
I call my neon WILD CHERRY she looks like the one in the picture. Thank you.
NatashaNeon
NatashaNeon
How do I replace the TCM
Okay P codes P1694,P0700,P0605
All Automatic pulled P0605
Apparently so did dodge. they did not charge me for the confirmation my problem is I don't have the kind of money to have Dodge do it so my boyfriend and I will probably attempt this ourselves how invasive is it? Can you direct me to best place to find a decent part for cheap and anything else that may be helpful please?
Thanks,
NatashaNeon
Thanks,
NatashaNeon
