I got a 2000 neon 2.0 auto 108000 miles. I was driving down the interstate at about 70 and there was a huge hesitation it was almost like the motor quit for a second then it kicked back in and drove normally. Then about 10 miles later it did it again. You guys have any idea what it could be. I have replaced plugs and wires last year.
Thanks any help appreciated.
The check engine light came on and it has a code of PO340. Right now the car is super hard to start it turns over a lot nothing happens. I did manage to get it to fire but it stalled out when I put it in gear.
I just replaced the camshaft sensor and it fired right up the car used to idle really rough but that seems to even be quite a bit better. The car now starts fine and only idles a little rough. Thank you for the help. I will drive it more and see just how good it is.
Thank you.
