Loose and sticky PVC hose
Hello All!
I have a question
My engine started making a whiny noise in idle. When I accelerate, the noise goes away until the second I let off the gas. I checked under the hood and noticed that the exterior of the PCV hose (bottom hose?) was wet and sticky. As I was wiping the hose off it easily came loose off the PCV valve. I placed it back on and it stayed on during my drive to work, but it does not fit snuggly on the valve and I am concern why it was that loose to begin with.
Do you think the wrong valve was put on during last repair? Or is the hose suppose to be kinda loose? Should I get a hose clamp?
2005 Dodge Neon non-Turbo
Thank you
I have a question
Thank you
