Ignition Lock Replaced - Cannot Remove Key Now!
Old 12-31-2015, 01:52 PM
airomero83's Avatar
airomero83
airomero83 is offline
Exclamation Ignition Lock Replaced - Cannot Remove Key Now!
Hi!
I have a 2002 Dodge Neon and I ended up replacing ignition lock cylinder since I was able to remove the key while the car was running!
Replaced the cylinder, re-coded to accept old keys, and inserted cylinder back into the car. I am able to twist the keys just fine, car turns on, but I am unable to remove the key now!! I think it's I'm unable to turn it back to the "Off" position...
It's killing me, I have tried twisting and jiggling the key. What am I missing here?
Old 01-02-2016, 03:37 PM
richards83's Avatar
richards83
richards83 is offline
Is you car a manual or automatic? I'm not that familiar with the Neon lock cylinders, but I know that the cars with manual transmissions have a button next to the igniton switch that has to be pushed before the key can be turned to the off position. I'm wondering if your issue is related to that.
Quick Reply: Ignition Lock Replaced - Cannot Remove Key Now!
