New to me Neon - lost key
Old 04-11-2016, 08:15 PM
myraus's Avatar
myraus
myraus is offline
Default New to me Neon - lost key
Hi everybody,
I just got a 2001 Neon from my next door neighbor because he was tired of it.
Now the only problem is that I was gone on the weekend and he supposedly put the key on top of one of the tires on my Dakota but never mentioned that to me before I moved the truck so the city could get the streets swept up. Well, I'm assuming it has gone by-by and all he gave me now was a cut key which only opens the door. I tried it in the ignition switch and it turns, dash lights come on but it doesn't crank.
Is there a way to bypass the security system to start the car? Can I just replace the lock cylinder with another with it's own matching key and get it to start?
If anyone can help, I'm all ears!
Old 04-11-2016, 08:37 PM
jkeaton is offline
Dodge Forum Administrator
Dealer or locksmith.
Old 04-11-2016, 08:57 PM
myraus's Avatar
myraus
myraus is offline
It would have to be coded to the car, right?
Old 04-11-2016, 11:59 PM
myraus's Avatar
myraus
myraus is offline
Or is there a way I could bypass the immobilizer?
Old 04-15-2016, 10:16 AM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
you can take the ignition switch off the cylinder lock, has 3 small security hex screws but a small flat blade will take them out an just start it with a screw driver until you get a new key I been doing that on my 2000 beater for years after going thru 3 lock cylinders
Old 04-16-2016, 09:20 AM
myraus's Avatar
myraus
myraus is offline
TejasMtnBiker, does your car have an immobilizer on the steering column? The key with the transponder chip inside it?
Old 04-21-2016, 07:01 PM
TejasMtnBiker
no mines an 2000, Im just stating how I got mine to start with multiple broken lock cylinders over time
Old 04-22-2016, 05:05 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
You could change everything in the system out to a non-immobilizer system. That's kind of the whole purpose of the system: to make it difficult to steal your car without the right key
Quick Reply: New to me Neon - lost key
