Neon clutch problem
Neon clutch problem
I have replaced the slave and master cyl in my 2003 neon but have absolutely no pressure on the pedal... have bled the system repeatedly using 3 bottles of dot 3 fluid and still nothing... can still hear what sounds like air in the lines and did bench bleed both parts... please help... I think I may have figured out my problem... there was a crack in the valve on my reservoir... haven't replaced it yet but I believe this may be the answer to my problem... will update if correct
Last edited by Simplesinger01; 05-22-2016 at 09:46 PM. Reason: Found an issue that may be the root of the problem
