2003 Neon parking light bulb replacement
Trying to figure out how to change the parking light bulb that is below the bumper on the passengers side. Any suggestions. There is 1 screw on the front of the lens but when I take it out it doesn't do anything. Also looks like you can't get to it directly under the front bumper. Any help?
Not that easy. literally turned out to be a 2 hour job. There is a panel under the bumper that has to be removed. Then there is not enough space to get your hand in back of the socket to remove the lamp. And I have small hands. So now you have to remove the whole assembly which has 2 nuts on the back. Push it out the front. Replace the lamp and reinstall. leave it to the morons that design these cars. Hey maybe you could have a couple screws on the lens and a gasket to make it easier.
Trending Topics
