I drilled it out in the car it came out. The ignition housing assembly is actually pressed onto the steering column and is very hard if not too difficult to remove for anyone trying to fix this same problem. It drilled out fairly easy in the car I used a center drill have to be careful not to drill the housing. Now to put it back together.
