Need Help Please
Need Help Please
I have a 2001 Neon SE. Car started fine no problems then started having transmission problems. Its an automatic. I pulled out the tranny and and put the other one on. Reconected everything, and now it doesnt start. It just clicks.
All lights on dash, headlights, radio, dome, everything works fine. Connected the scanner, no codes. Checked all fuses, all good. Tought might be starter, installed new. Same problem. Checked engine harness wires and they good. Battery is good. Fuel pump work. I have spark. New spark plugs, ignition wires and coil pack. I put car in neutral same thing. Tried jumping the car, same problem. Just clicks wont crank over. Cranked car manually rotates fine.
Running out of ideas. Can someone give me some tips. Getting really frustrated with it.
I checked them and they are connected. Unplugged and checked connectors and they look good. I did scan it but no codes.
I had to look up some old posts; been some time since I've had a Neon. You've got a big one going from the negative battery post to the starter bolt, which then splits at the starter bolt and also bolts to the battery tray. Then there's one that goes from the negative battery post to the frame under the air box. Those are the three on the driver's side. On the passenger side, you have engine block to frame and engine mount to frame, both attach to the frame by the strut/windshield washer fluid line. I forgot to tighten one of those last two on the passenger side. At least, when I removed the transmission, those had to be undone to allow the engine to drop enough with the transmission.
Trending Topics
Is the neutral/start switch electrical connector plugged in? It's the one low down drivers side front corner of the tranny case. Stuffed in with all the computer wiring just in front.
Or maybe the N/S switch is faulty or sticking, so give it a thump.
More thoughts for consideration, let us know what you find.
EDIT: Can you tell us what "clicks", when you go to "start" to crank the engine?
