DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 01-08-2006, 07:17 AM
vpiflyboy vpiflyboy is offline
Default Weird "FUSE" light in mileage display
I have a 2000 that I bought this week with a weird problem. The car started displaying the word "FUSE" where the mileage is displayed. My dome light was not coming on at all also. Above the mileage the word "Door" would not extinguish.
I checked the fuses under the hood and inside. All of them were still good. It seemed to me that the car thinks the door is still open and there is a problem with a fuse somewhere.
I popped open the dome light cover and.... there was no bulb in the socket!! I got out my voltmeter and it was reading 12-14 volts in all configurations except with one fuse pulled under the hood (int lgt I think). I tried doors open/closed with car on/off and key in on and acc. It seems to me that the car thinks that the door is open all the time and the dome light stayed on all the time, therefore the previous owner simply pulled the bulb out to keep the battery from dying and the light on during night driving.
Has anyone seen this before? Any idea of what it is? A door switch maybe? Any experience with this problem is appreciated!! I did a couple of searches and came up with nothing.
Cheers!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-09-2006, 01:23 AM
EDK EDK is offline
Default RE: Weird "FUSE" light in mileage display
go to this link http://www.dodgeforum.com/m_302608/tm.htm
__________________
2000 neon WENT KABOOM
2007 DODGE RAM
http://www.cardomain.com/ride/2214951
Old 01-09-2006, 01:27 AM
casper casper is offline
Send a message via AIM to casper
Put a bulb in the socket and replace the fuse and you should be fine.
__________________
1998 Neon- Iceman intake, Pacesetter exhaust, Megan racing short shifter, Kirk Racing header, AFX solid race front mount, AFX solid bobble strut
Come play hood wars
http://www.hoodwar.com/register.php?REF=329
Old 01-09-2006, 06:30 AM
I did that and the light stayed on ALL the time, except when I pull fuse #13. I fixed the "DOOR" above the mileage today (faulty switch I think, just did some wire tracing and shaking), but the dome light socket still has 12-14 volts ALL THE TIME.
I put a new bulb in, swapped (not replaced) the fuse with another 15 amp fuse. Same probelem-> the light stays on. Any idea what the stealership did for ragingneon last Sept? I got that thread in my search, but it did not help. I do not have a check engine light and no codes are popping up with the code check. Just "FUSE" in place of the mileage when you start up.
Any suggestions are appreciated!!
Old 01-09-2006, 07:33 AM
01 r/t 01 r/t is offline
u have to replace ur timing module that controls the doamlights.
Old 01-10-2006, 03:55 AM
RadarLove RadarLove is offline
The light comes on when a connection is made to ground. Typically, this happens when you open a door - power is always going to the light (as long as the fuse is in), but the light will only come on when grounded, which is where the door switch comes in (completes the circuit). So my guess is you have a short to ground somewhere in all that wiring, which includes all door switches and the illumination/dimmer switch.
Best of luck!
__________________
1995 Plymouth Neon
2006 Mazda5 Sport
I know nothing about cars or engines, at least according to Neon2.0T. Must be true then!
Old 10-07-2009, 06:10 PM
hirsch21 hirsch21 is offline
I have a 00 plymouth neon with the same problem, im guessing they are the same. Mostly the same anyways.
My question is: Is there a inexpensive and easy way to test for these types of problems. Like checking the door stop?
Any help would be greatly appericated!!
Old 10-07-2009, 07:58 PM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
Mine showed fuse when there was a bad ground in the engine bay?
__________________
Old 10-07-2009, 08:56 PM
neisg1 neisg1 is offline
Vehicle: 2001 Chrysler Neon LE
Default from the 2000 dodge manual
In the event that the instrument cluster looses
communication with all other modules on the PCI
bus, the cluster will display “nobus” in the VF display.
The VF display also displays “Door”, “Cruise”,
“Trac”, and odometer trip or total.
If the cluster does not detect voltage on the courtesy
lamp circuit, the message “FUSE” will alternate
with the odometer/trip odometer for 30 seconds after
the ignition is turned on and for 15 seconds after the
vehicle is first moved. The lack of voltage can be due
to the M1 Fused B(+) (IOD) fuse being open, a bad or
missing courtesy lamp bulb, or a circuit problem.
Tags
2000, 2005, code, coming, displays, dodge, durango, fuse, illumination, light, mileage, neon, neons, panel, problem, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
