2000 Neon spark plug gap?
Old 03-28-2006, 05:22 PM
defster25's Avatar
defster25
defster25 is offline
Default 2000 Neon spark plug gap?
Whats up everyone? I just got a set of Bosch Platinium+4 spark plugs and I was wondering if I had to gap them? If so....what do I need to gap them at?
Old 03-28-2006, 07:38 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
Default RE: 2000 Neon spark plug gap?
I think its gapped to .035...and for gods sake dont stick those platinums in your neon...iridium or copper is the best for our engines, so if you can take them back do it fast!
Old 03-28-2006, 08:11 PM
defster25's Avatar
defster25
Whats so bad about them?
Thanx for answering my question
Old 03-28-2006, 08:20 PM
moobit's Avatar
moobit
moobit is offline
i second that, i want to know what makes them so bad for neon engines?
Old 03-28-2006, 09:20 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
Causes them to misfire really bad...plus copper and iridium is a much better conductor...
Old 03-28-2006, 09:29 PM
defster25's Avatar
defster25
Well i just put my Bosch's in, and im liking the way it drives, i can notice a difference.
Old 03-28-2006, 10:00 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
Well then i'll explain in more detail...there really havent been any huge horror stories about platinum plugs but the major problem is how long they last, since 1/2 of the plugs fire in a reverse polarity, 1/2 of them wear faster, thus causing problems down the road with misfires and general loss of performance. There have been many cases on the .org where people have installed platinums and after a few hundred miles or so they throw codes all over the place. After taking out the plugs and even throwing in some cheap NGK V-Power or Champion's, they've been running fine ever since. Another issue is that Platinum holds heat more then a typical copper or iridium plug. Keeping the heat lower decreases pre-ignition and fouling of plugs, thus extending the life of the plugs more and keeping better performance and gas mileage...
Old 03-28-2006, 10:14 PM
moobit's Avatar
moobit
moobit is offline
Makes sense. thanks.
Old 03-29-2006, 01:23 AM
defster25's Avatar
defster25
I'll keep them in for a while and if i notice any bad changes i'll take them out, thanx for the advice [sm=smiley20.gif]
Quick Reply: 2000 Neon spark plug gap?
