Biggest tire that will fit?
Old 06-28-2006, 09:58 AM
mochadach's Avatar
mochadach
mochadach is offline
Default Biggest tire that will fit?
I have a 2004 Neon SXT that is completely stock right down to the P185/60R15 tires. Does anybody know if it is possible to put P205/60R15’s on the stock factory mags (6” width) on the back of the car and have enough clearance with the bottom of the plate holding the spring on the struts. I have carefully measured this and it seems like they should fit with about 1/8” to spare. Anybody tried this before?
Old 06-28-2006, 09:05 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: Biggest tire that will fit?
Try tires.com or tirerack.com, either one will tell you what size you can run based on your car.
Old 06-29-2006, 06:15 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
you might be able to....i ran 215/60 14's on my 98....no rubbing or anything
Old 06-29-2006, 12:05 PM
das2123's Avatar
das2123
das2123 is offline
^^^They are 15" rims
Old 06-29-2006, 02:56 PM
spudsterier
i know i was just sayin...the ones i had were alot bigger then stock so maybe the same would work for him
Old 06-30-2006, 06:39 AM
mochadach's Avatar
mochadach
The reason I want the 205/60's is because I want to put white lettered tires on the car - 185/60 or 195/60 on the front and the biggest I can fit on the back and the BFG Radial T/A's I want do not come with RWL's on the 205/55's. I know the old "white-letter-smaller-on-the-front-bigger-on-the-back-tire" thing is a bit out of style but I still like it.
Old 07-02-2006, 03:15 AM
kungfumasta's Avatar
kungfumasta
kungfumasta is offline
ok, so I have a 05 dodge neon and i am running 215/40/17" tires, so i dont see why 205/60/15" wouldnt fit... Just as long as the tire does not exceed too far past the width of the rim it should be fine. My 17" rims are about 7.5" deep, so im sure that the stock 15's should be able to fit no problem.
Old 07-29-2006, 08:08 PM
flynunn's Avatar
flynunn
flynunn is offline
Will stock SRT-4 rims fit on a 05 Neon SE tiresize is stock 205/50/17? The spring plate is rubbing tires...has any one been able to work around this problem. [:-]
Old 07-29-2006, 09:00 PM
03neonRT's Avatar
03neonRT
03neonRT is offline
You either need SRT-4 struts, or go down to 40 or 45 series tires...
Quick Reply: Biggest tire that will fit?
