DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
  #21
Old 11-01-2007, 04:34 PM
Dustinicus Dustinicus is offline
Default RE: The Official MegaSquirt FAQ
Off a little i am seriously ordering thiskit right now and i wanted to know if the (MegaSquirt I ECU kit v2.2) has a spark controler included with it, because i will not be needing that right away, i am more interested in fuel management, then ill go to spark later down the road, i am running my shadow N/A for now, and im not even sure if this is the right place to post such things but i did a search and this was the first page that popped up, i guess i just want a fuel management sustem, the price looks right if if some one shot me an email or pm with any additional information that would be wonderful, i guesss along with that kit i want to know if it has a spark controler with it, and if there are any other things i should be ordering along with this kit...
I know I ramble...
Thanks for listening...
-Dustinicus
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 11-05-2007, 08:17 PM
spikeymikey87 spikeymikey87 is offline
Send a message via AIM to spikeymikey87
yea it will have the spark control with it, but you dont need to hook it up if you dont want to. this is a neon section, but i think its the only megasquirt thread here lol. try msefi.com for more questions. you will probably get a better response there
__________________
Megasquirtin all over your face
  #23
Old 11-27-2007, 10:48 PM
2001dodgeneon 2001dodgeneon is offline
Is mega squirt the best engine management for a neon?
  #24
Old 12-28-2007, 05:52 PM
dtjackten's Avatar
dtjackten dtjackten is offline
2nd gen neon peace keeper
Dodge Forum Moderator
Vehicle: turbod 02 dodge neon
Send a message via AIM to dtjackten
ok, now i know that ms has a TON of advantages!!! a friend of mine has one on his civic and loves it, he talks about a "pretune" if u have a wideband?? i have a wideband, and need to know will this work with our neons like it did his honda?? it gets the ve tables to run rich so the car is able to be driven, even though u have to lean them out later..... is this something that we can do as neon owners?? he is going to help me with the install and i need to make sure that he is going to be giving me right info???
also
he has a rpm shift light in his car( ran off ms) can we do that to the neons even the wiring is ran off of a 2 cylinder rating? i really want to do this and get rid of my tach, keep it kinda sleeperish??????????
__________________
working all winter to scare the hell out of smallblock in my 400 hp monster.....
built bottom end and 20psi here i come!!!
  #25
Old 01-02-2008, 02:24 PM
if you mean start with a base map and then have the megasquirt tune the rest of it for you then yes, it can be done. autotune is a feature in megatune that does it, but in my opinion it works like crap. i prefer to go out for a drive while logging the whole thing and then put it into the logviewer program which haa something called ve analizer. it will look through your whole log and give you a suggested ve table. that works great..
and yes you can run a shift light. its one of the outputs, but you have to solder something on the main board. i dont know exactly how to do it, your friend might though, and i know it says it in the megamanual. i believe the 2 cyl thing doesnt matter because it probably runs off the crank signal, which is the same way it sees rpm anyway so i assume that would look to the same thing
__________________
  #26
Old 08-17-2008, 05:14 PM
rsalgado29 rsalgado29 is offline
2005 Dodge Neon
Vehicle: 05 NEON SXT
Is the MS only for the srt-4 neon or could I use it for the sxt 05 non turbo?
I got the jet chip but it was a waste of money nothing happen and here in colorado it's been raining and It got water damage and my car wouldn't start I was thinking it was my CAI that grab water but it wasnt it was the jet product because the symptoms where that my car started but then it turn oof and the Tachometer wouldnt work, after removeing the jet control module the check engine light when on so I took the batery cable off and then put it back on and it works. chasam the jet product suck balls.
IS that true that all the stock pcm for 05 neons void every bolt on upgrade that I put on?How bout if I put the APEXi S-AFC NEO would that work? or is that only for turbo and vtec I found that at modernperformance.com but it only talks about vtec.
o I need to put a clutch would a stage 1 fidanza with flywheel work or its BS? should I buy the oem one?
My neon is an 05sxt I only have the srt exhaust and the cai and UDP.
__________________
Fear Me
  #27
Old 08-20-2008, 07:27 PM
first, no your pcm will not cancel any upgrade you put on. you would get more power if it were put on a 02 and below neon, but you still do get some power. yes, you can run your car on a megasquirt. i had mine, non turbo and running on the megasquirt for quite some time and it was fine. i actually am selling my megasquirt, with all the sensors and wiring you need, so if you want it pm me.
__________________
Tags
1995, coilpack, crank, dakota, dodge, face, fan, harness, megasquirt, neon, ngc, project, radiator, signal, srt, srt4, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
