View Poll Results: Gears~ Whatcha got?
3.21
2.54%
3.55
36.44%
3.73
0.85%
3.92
14.41%
3.90
0
0%
4.10
21.19%
4.56
16.95%
4.88
5.93%
Other (Please Post)
1.69%
Voters: 118. You may not vote on this poll
Gears
Old 07-04-2010, 11:44 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Now I have 4.56 gears.
Old 07-05-2010, 06:28 AM
Pacmanloads's Avatar
Pacmanloads
Pacmanloads is offline
4.56 Yukons, Love them !
Old 11-01-2011, 11:08 AM
8uzzsaw's Avatar
8uzzsaw
8uzzsaw is offline
3.55 yay me.
Looking at swapping out for some 4.10's! Anyone in New Brunswick do gear work?
Old 11-01-2011, 06:32 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Forgot about this one. 4.10's for me, woo hoo!
Old 12-10-2011, 03:38 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
4.88's here with 35's. Power is not a problem lol.
Old 06-13-2012, 08:33 AM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
So, what does getting a different gear ratio do? Won't you lose out on top speed by going with a higher gear ratio?
Old 06-13-2012, 09:56 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
Are you really concerned about top speed in a TRUCK???
Most folks change gears to compensate for larger tires. Keeps the engine at pretty much stock RPM vs. Speed when going to larger ones.
JUST changing gears, and NOT using larger tires would put the engine at a higher RPM vs. Speed. Of course, your truck would accelerate better... but yes, you would lower theoretical top speed. In reality, top speed is more limited by the engine simply not having enough power to push your truck thru the air with its brick-like aerodynamics.
Old 06-13-2012, 10:34 PM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
Hahaha a lot of people here have 4x4 pickups, I've only got 2WD so I'm going more for a race truck haha while still keeping functionality of a true pickup. So seeing as I'm keeping stock tires, what gear ratio do you recommend for me?
By stock, I mean the same dimensions
Old 07-29-2012, 03:12 PM
agoodman53188's Avatar
agoodman53188
agoodman53188 is offline
for now i just got stock 3.55, looking to eventually change it, not sure what to tho. ill figure that out when the time comes that I can afford to lift the truck and put 35s on it, gonna be a while tho, wife's pregnant, so I gotta save all the pennys that i can right now.
Old 12-19-2012, 01:53 PM
Jigabop's Avatar
Jigabop
Jigabop is offline
stock 4.10s and hate them.
wish I had 3.55s
truck tops out and needs to shift too fast. even with 35's 4.10s are too low for a diesel. gimme some 355s and I'll still light up the 35s with them
probably gain 3-5mpg and 20mph top speed as well
Quick Reply: Gears
