Old 08-05-2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
DIY - Transfer Case Saver install (NP231, NP241, NP243)
Old 04-17-2013, 01:07 AM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
No, that is totally normal. 231's came in 1500's. The T-case saver is more than a pipe bushing, and yes it will.
Old 05-12-2013, 12:26 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
lolz, pipe bushing!
My snap ring was in place and in great condition. We'll see though as I'm going one seal deeper than you. Bumping this for the knowledge!!
Old 05-12-2013, 08:48 PM
Wombat Ranger
I actually did this after rebuilding my transfer case. Hows that for one-upping?
Old 05-13-2013, 08:39 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wait a second, that is 1-upping? A rebuild? I'd say you're a -1 in that mine is not in need of a rebuild. hahah!!
So, looking again, you didn't have to take the output bearing housing off for this....? Undoing those bolts, does the output bearing on the shaft come off with it?
Old 05-13-2013, 11:08 PM
Wombat Ranger
^^ Ouch!
Yes, the bearing is pressed into the output bearing retainer.
Old 06-06-2013, 08:32 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Completely forgot about this. Add this link to your OP broham. I need to get this.
http://www.drivetrain.com/parts_cata...ase_saver.html
I think I'm going to redo the RTV on the case halves too. Appears to be weeping from the outside look. Did you ever do that over your "rebuilds"?
I've got residue everywhere and I just went to wipe down to try and get a better idea.
Old 06-07-2013, 09:48 AM
Wombat Ranger
Yea when I had the case apart I put new slicone between the case halves. It didn't leak at all. Till it broke in half haha. I will add the link when I at my computer.
Old 10-20-2013, 06:17 PM
Cartalk2's Avatar
Cartalk2
Cartalk2 is offline
What are the symptoms when the snap ring has failed? Do you get abnormal vibration? Do chuncks of metall appear when you change the fluid? Tail shaft seal fails?
Thanks in advance.
Old 10-20-2013, 07:04 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Usually its just odd noises while moving. Not too bad to check. Drop the driveshaft, pull the tailhousing, and see if it is still there.
Old 10-20-2013, 07:08 PM
topkin's Avatar
topkin
topkin is offline
hmm interesting. Glad I cought this. I have my transmission and transfer case out of the truck now, I am going to take a peak tomorrow before I put it back in.
Quick Reply: DIY - Transfer Case Saver install (NP231, NP241, NP243)
