I have not delt with them but I know many Ram/Dak owners who have and they have nothing but good things to say, they also cary modified barrel intakes (shorter runners) and a number of other parts for the magnum engines
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Ram 1500 4X4
1966 Plymouth Sport Fury
Sponsored Links
Registered users do not see this ad. Click here to register for free!
can the catalytic converter be cut out ? its welded on.dont havve the $$ right now to buy a new one.i need help my trucks been down for about 3 weeks now.can i unclogged or repaired it?
My ignition cuts out during a lay over. I have a '98 Dodge Ram 1500 with a 5.2, auto, TWD. Everything runs perfect and then with now warning I come out to start in the morning or two hours later or whatever and no spark. I have had it to a dealer and two shops that really know their stuff and they specialize in electronics on vehicles. They can't find it. No error code is provided by the on board computer, nothing. Then with no warning the vehicle starts right up the next time the key is turned. Once it took a week to start again once a couple of hours. I REALLY COULD USE SOME KNOWLEDGABLE ADVICE. THANKS.
crank sensor or coil could be causing the problem. my bet is on the crank sensor. whatever it is, it is heat related. you can try to get a can of freeze spray and spray the crank sensor when it wont fire, might be tough because of it's location but it's worth a shot.
i got a question, when i get deep into the pettle or start pulling a hill, my ac will stop blowing out of ts set vent and go into what i gess is defrost mode. what is the deal with that. the truck is a 98 quad cab 4x4 360
there is a check valve on an vacuum line going thru the firewall that is bad. follow the vacuum lines off the intake manifold to the firewall and you'll find it.
Hey Guys I have a 99 Ram 1500 small v8 auto regular cab. The Check engine light came on . My brother checked it with a reader & it's the speed sensor circuit malfunction. I have the part .does anyone have any pics of the connection so I can see where to push the flathead screwdriver in to get the electrical connection off ?
ok let me start off by saying that im am new to trucks...i am a Honda guy...which i kno u guys r probably gonna bash on me for it but its the truth....dont worry im not a ricer , into body kits and giant wings and stuff , im into JDM....anyways i just want to know what kind of tranny is in anauto97 Ram 1500 5.9 Mag.???? i was offered i free truck from my dad if i put up the $$ to fix the suspension damage after a front accident (nothing major, i hope, good excuse to go with heavy duty off roading suspension [8D]) and i have to replace the tranny.....but i have not had any luck with finding usefull info, so i figured i would find a forum, not im here[/align][/align]all since i am into Hondas and motor swaps and conversions and such i am curious.....will a newer RAM hemi fit in my 97?? and would it be worth the swap??....also has any1 thought of converting the front end on an older ram to a newer ram??....ok ok let me stop im getting in over my head but please some help!!!![/align][/align]thank you very much for your time and help[/align]DRE[/align]
How universal are the wiper switches for Dodge Rams? I have a 1996 Ram Extended cab 5.9L. Most Chrysler switches I've seen for Jeeps and Vans/Trucks from the mid 90's all look the same.
__________________
1996 1500 2wd 360.
Never Satisfied. Always Gratified.
