DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram > 2nd Gen Ram FAQs
Closed Thread
Thread Tools Search this Thread
  #41
Old 11-08-2007, 11:17 AM
ICEMAN_CH ICEMAN_CH is offline
2001 Dodge Ram 1500
Vehicle: 2001 Ram QC LB
Default RE: Dodge Ram FAQ
Quote:
ORIGINAL: arcsum68
Holy crap, just tested my cat with a temp gun, 700 degrees in and400 degrees out, time to get a new cat.
Thanks for the information!
That is the way it's supposed to be.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2001 QC RAM LB HD - 285/75/16 - 3:96 gears (came stock - Hughes Plenum kit - Cloyes double roller timing chain (advanced 4) - 180 T-Stat - Flowmaster Delta 40 Dual Exhaust - Pacesetter LT - Hypertech set to 93 octane
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #42
Old 11-08-2007, 11:26 AM
arcsum68 arcsum68 is offline
Quote:
ORIGINAL: ICEMAN_CH
Quote:
ORIGINAL: arcsum68
Page 1 ofthis thread:
Catalytic Converter:
The best way to test the cat is to have someone in the cab rev the motor to about 2000 or 2500 rpm's and put a temp gun on the input and output of the cat. the output should be around 50 deg hotter than the input for proper cat operation. if the temps are the same, the cat is not working, if the input temp is high and the output temp is low, you have a plugged cat and you should have it swapped out immediately.
I was 300 degrees hotter coming in than going out, it was definitely plugged up.
__________________
99 Dodge Ram 1500 SLT SB 4x4
  #43
Old 11-09-2007, 05:32 AM
steve05ram360 steve05ram360 is offline
Site Moderator
Dodge Forum Moderator
Vehicle: 2005 Ram CTD 4x4, 2000 audi TTQ
Quote:
ORIGINAL: ICEMAN_CH
Quote:
ORIGINAL: arcsum68
uhhh.. no... hotter coming out than going in. you have it backwards, his cat is definately plugged.
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
  #44
Old 11-09-2007, 11:14 AM
2001 Dodge Ram 1500
oh I seee. sorry,
__________________
  #45
Old 12-06-2007, 01:12 PM
tothewall tothewall is offline
Default RE: Headlight modification
Quote:
ORIGINAL: bamory
Found this while surfing the net, tried it and it works great, makes all four bulbs burn at once for an extremely bright drive at nite
Possibly a new solution to an old problem.<br><br>I wanted to have my low beam lights to stay on when switching to high beams. I was poised with pen in hand getting ready to write a check for a Brite Box. Then I remembered that I was an electrical engineer and should be able to do this myself.
Great statement. LMAO
__________________
Rides:
'01 Ram2500 ... 4x4 ClubCab Shortbox 5.9L
'08 Jeep Wrangler Rubicon
Yellow with fuzzy dice, travelling Buddha and peace sign complimented by 4" RocKKrawler, 35" TrXus Muds & Warn PowerPlant 9500. Lifted, Locked and Loaded baby!
  #46
Old 12-05-2008, 08:25 PM
momosbrysun momosbrysun is offline
Default please help 97 dodge 360 2WD
i was droping off my son to school and my truck just died while i was at idle and the only way it will start is if you hold the gas petal down, it will idle at about 900 rpms but if you put it in drive it kills it. i took the TB off and cleaned it replaced the air idle control sensor, theres new plugs ,wires,cap,rotor, please help im about to pull my hair out just bought the truck about a week ago its got right at 105000 miles on it.
  #47
Old 12-12-2008, 07:40 PM
csalinastx csalinastx is offline
Default 2000 Ram 1500
http://www.dodgeforum.com/m_340929/tm.htm Link is broken
I was wondering if anyone here has a current link to the Service Manual.
Any help would be great.
Thanks
Chris
Dallas ,TX
  #48
Old 01-01-2009, 11:08 AM
sawtooth's Avatar
sawtooth sawtooth is online now
Trans Check Valve Delete
Some one should place this one in the DIY section before it gets lost.
Found one possible error. The Napa part no. for the "quick disconnect (Dodge, Jeep) transmission line connector" is 730-5027, not 730-5927.
http://dodgeforum.com/forum/2nd-gen-...ve-delete.html
__________________
'96, 1500, 5.9, 4X4, auto
  #49
Old 01-17-2009, 01:47 PM
Erik Kuijvenhoven Erik Kuijvenhoven is offline
1998 Dodge Ram 1500
Vehicle: Dodge Ram 1500
Send a message via MSN to Erik Kuijvenhoven
U prob tried allready but could be ure fuel filter
__________________
5.9, magnaflow 3.5", Tinted Everything, Pwr everything, Htd mirr, Tow pkg,Trans coolr, 4 door, LED emergency light kit, 52mm tb Nitto terra grapplers
  #50
Old 01-24-2009, 11:54 PM
MarkBall MarkBall is offline
Send a message via Yahoo to MarkBall
Tagged for future reference
__________________
2001 Dodge Quad Cab 4x4
285R7516's Nitto Terra Grapplers
3.54:1 gears
AIRaid CAI
Flowmaster Series 40 cat back
High flow cat
Jet Chip
NOW TWIN TURBO'S ON THE WAY!!!!!!
Closed Thread
Tags
1500, 1999, 2002, 59, beams, diagram, dodge, fog, ground, high, light, low, ram, stay, vacuum, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
