09-02-2014, 09:10 PM
New headlight switch. Also got the hd harness from lmc truck so it doesn't melt again.
09-02-2014, 09:52 PM
Quote:
Originally Posted by
stewie01
When did you fix the clutch?
I didn't. It still chatters away when depressed. Might have to give a zanex.
It only makes chattering noise when I push the pedal down. Otherwise it's quiet and holds fine.
09-02-2014, 10:52 PM
Jigabop,
I have a extra brake controller if you need one.
09-03-2014, 09:15 AM
Replaced my heater core...WOW...took myself and a neighbor 4 hrs
09-03-2014, 02:05 PM
Wildman4x4nut
Jigabop,
oooh
is it the kind I can plug into one of them OEM adapter things?!
the one that came with the truck the P/O wire tapped into all kinds of wires under the dash and made a mess.
I still have to cut all of those wires out of there and fix them.
09-03-2014, 08:51 PM
ordered my new exhaust today. was 185.99 out the door from advance auto parts. should be here by the end of next week! its a dynomax 17342
single 3" exhaust. should sound ok.
snowboundrmk
Add headlight relays, there's a write up in the DIY section. If it happened once, it'll probably happen again.
09-03-2014, 09:42 PM
Dodge Forum Administrator
Arde
I think the HD harness from LMC Truck IS the relay harness. Pre-wired. Plug and play.
09-04-2014, 10:36 AM
That'd be cool, I was thinking that HD might just be heavier gauge wiring.
09-04-2014, 10:40 AM
Yeah, it came with relays.
