  #15671
Old 08-09-2016, 12:32 PM
evilemokid94's Avatar
evilemokid94
evilemokid94 is offline
Originally Posted by Ham Bone
Most of the time you can pop the wheel bearing out using a short impact extension. Thread the bolts in half way, put the extension on, then turn the steering wheel (while it's on Jack stands) until it presses into the axle to pop it loose.
I tried.....it bent the extension
  #15672
Old 08-09-2016, 12:33 PM
evilemokid94
If one hose is bad, replace them both. Save yourself the aggravation of having to do it again later.
that's the plan
  #15673
Old 08-14-2016, 02:32 AM
beeker's Avatar
beeker
beeker is offline
Removed dash to finally replace heater core and evaporator. It's been leaking a few years now and don't trust any shop to touch my dash. I saw a dealership destroy one in a work truck. It's a big job, no really good writeups on the task either. I had the ac evacuated last year. Replaced the evaporator core was 70 percent blocked with caked dirt and pine needles. It was nasty. I was being gentle and created 2 nice long cracks in my flawless dash just from the weight and flex. Spent all day on it taking my time amd only got the air box put back together with new cores. Got new o-rings for the AC. Going to finish up tomorrow.
  #15674
Old 08-16-2016, 02:09 PM
BryanLZ's Avatar
BryanLZ
BryanLZ is offline
Replaced my headlights and installed the relay wiring harness from LMC. Converted the single bulb headlights on my '97 Sport to the dual bulb setup seen on the '98 and up.
  #15675
Old 08-16-2016, 10:48 PM
Spillage's Avatar
Spillage
Spillage is offline
Originally Posted by BryanLZ
...to the dual bulb setup seen on the '98 and up.
98½ and up (built after May 30th)...
(minor technicality)
  #15676
Old 08-17-2016, 06:09 AM
duke07's Avatar
duke07
duke07 is offline
Installed mopar mud flaps and adjusted the headlights.
  #15677
Old 08-19-2016, 11:55 AM
schmidtp's Avatar
schmidtp
schmidtp is offline
Magnaflow Y Pipe and Cat on. Goes to a thrush turbo and sounds really nice.
  #15678
Old 08-19-2016, 06:06 PM
tincan57's Avatar
tincan57
tincan57 is offline
What did I do, I blew the bugs out in E Town.........Speaking
of blowing the bugs out, I've found if this old truck goes two
days without being started, it runs sluggish the first 2 miles.
Keith
  #15679
Old 08-20-2016, 12:09 PM
renardk764's Avatar
renardk764
renardk764 is offline
Driving home the other night she shut down on me. Luckily, I was in the neighborhood and not on the freeway doing 70. After 30 minutes of poking around under the hood, I moved the wire loom that was setting on the bolt that holds the air hat on. It was a miracle! Truck started right up and finished the trip home. Took a look today and the wire loom split was open a smidge allowing one of the wires to rub on the nut, wearing through after a bit, and shorting out. Gave the dreaded "No bus" error. Taped up and double insulated the offending wire, problem solved. Whew!
  #15680
Old 08-20-2016, 12:40 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
You really dodged a bullet on that one!!
As they always say, I'd rather be lucky then good
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
