Replace the Plenum or go air gap route?
So then I guess that's why we have such a terrible problem with the steel pans on our aluminum-cased automatic transmissions leaking all over the place, huh?
The stock plenum gasket isn't thick rubber coated like the trans gasket, nor was it metal core, and is also very thin compared to the trans gasket. imho, your comparison is comparing apples to oranges. Find something closer to compare with
How confident are you guys that the problem is in the bolts and NOT the metals? Lets say I were to change my gasket and use the steel plate with shorter bolts instead of an aluminum plate which I planned to do, sorta like a long term test of this theory.... If you are right and it solves the problem then we will have learned a great lesson for this place, if you are wrong and it blows out again....hmmm, maybe you guys buy ME an airgap or at least a hughes plate?
I read somewhere that some guys were o-ringing the plenum. You could also port kegger some then tig it. Or buy used m-1 on ebay or boards. Lots of options really. And yes, different metals expand and contrast at different rates. This varies with material and varies with thickness. Thicker aluminum would expand/contract slower than the thinner. A combination of the thicker aluminum and that making bolts shorter in the case probably both contribute. That's probably why a thin metal pan works on aluminum tranny.
