FireDodge's 360 Build
Old 10-01-2013, 04:41 PM
FireDodge's Avatar
FireDodge
FireDodge is offline
Default FireDodge's 360 Build
So I've been trying to get this done for the past, oh I don't know, year or so. But I am now in a position to finally order my parts and assemble the motor. Back in January/February I had a spare block cleaned and honed out by a local shop. I will be using the stock bottom end, but replacing all bearings and rings and whatnot.
The top end is what I will be ordering over the next few days. Here is a short list of what I intend to get.
Odessa EQ 2.02 heads
CompCams 20-604-9 -- http://www.compcams.com/Company/CC/c...?csid=664&sb=2
Lifters/Pushrods from Chryslerpartsdirect.com
_____________
I already have a complete rebuild kit including all gaskets, bearings, rings, and that stuff. All this will be paired by my current M1 Intake manifold, 52mm Throttle body, double roller timing chain, SCT ( I know I will need new tunes), 4.56 gears, and Detroit locker.
A few things still, I was going to look into a high volume oil pump. Does anyone have a link to a good one (lower priced the better haha). And also if anyone has any other input that they'd like to share or persuade me feel free to let me know. As parts come in, I will upload pics for you ******.
Old 10-02-2013, 12:48 AM
snowboundrmk's Avatar
snowboundrmk
snowboundrmk is offline
Your not going to order stock length pushrods are you? You should measure. I would also recommend a stock oil pump. High volume is not really necessary and you just risk sucking the pan dry, especially if you 4 wheel and get off camber. Get some roller rockers too.
Old 10-04-2013, 11:57 AM
FireDodge's Avatar
FireDodge
I was told by someone at CompCams that stock length pushrods are what is recommended for the cam.
Heads and Cam are officially shipped and should be here mid-next week!
Old 10-05-2013, 01:49 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
I am running the 206029 CRS262HR12 and I bought a adjustable pushrod to check for correct length. I ended up with stock length push rods if that helps you any. I am using the EQ heads too. I am running a Melling High Volume oil pump can't tell you yet if it causes any issues. My bottom end is all stock like yours too. I am using the Hughes Engine Air Gap intake instead of the M1.
I went with 1.65 ratio roller rockers on the intake and 1.7 ratio roller rockers on the exhaust. They are Scorpion roller rockers.
My build thread is:https://dodgeforum.com/forum/2nd-gen...the-cheap.html
Old 10-08-2013, 01:27 PM
FireDodge's Avatar
FireDodge
Cam arrived at my buddy's shop yesterday and the heads should be there sometime today! I'll get pictures up possibly tomorrow if I can make it out, but I don't want to do a lot of work on my birthday .
Old 10-09-2013, 10:49 PM
snowboundrmk
Happy Birthday! lets see some pictures
Old 10-15-2013, 02:08 PM
FireDodge's Avatar
FireDodge
Heads, cam, lifters, pushrods all arrived last week. Haven't actually opened anything yet. My friend/mechanic who will be building the motor for me doesn't have a free weekend until November 2nd/3rd, so I have to be patient until then. And with less hours at work, funds have gotten pretty low, so I get to save up for any odds and ends I may need once the build happens.
Old 11-11-2013, 10:28 AM
FireDodge's Avatar
FireDodge
Well I finally got some time at the shop with a mechanic friend of mine and we assembled about 90% of the motor! I think next weekend (1.5 weeks) we will do the official swap. Took us all of about 5 hours to do with only one trip to the parts store for an oil pump and head bolts. all that is left is the timing cover, water pump, intake, valve covers, and oil pan...for the most part. Things were going so smoothly I forgot to take more pictures, but here is what I have!
Laying out pistons for new rings and installation...
http://i1210.photobucket.com/albums/...ps31d6c28d.jpg
Pistons installed
So pretty!
Double roller and cam installed...
Installing one cylinder head...
Both heads installed...
Difference between old block and brand new heads!
Rockers installed...This is how it sits now but in a bag until next Saturday/Sunday.
Edit: The rockers are the stock 1.6's but everything else in the head is brand new (valves, springs, yadayada)
Old 11-11-2013, 10:35 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
So a stock-ish rebuild?
Looks like it's gonna be a good engine when you're done.
Old 11-11-2013, 10:39 AM
FireDodge's Avatar
FireDodge
It's a stock bottom end. EQ 2.02's and CompCams 20-604-9. Plus the M1 that's currently on the truck.
Quick Reply: FireDodge's 360 Build
