FireDodge's 360 Build
Old 11-12-2013, 10:29 AM
FireDodge's Avatar
FireDodge
FireDodge is offline
Yep, that's a possible plan down the road.
  #22
Old 11-12-2013, 11:10 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Given the lift on that cam, I would stick with stock ratios though.
  #23
Old 11-12-2013, 11:15 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
still power to be gained going to a roller though
  #24
Old 11-12-2013, 11:16 AM
HeyYou is offline
Most certainly. More accurate, less friction. I still consider this a good upgrade.
  #25
Old 11-12-2013, 11:34 AM
FireDodge's Avatar
FireDodge
Just to clarify... Would I need stud or pedestal mount RR's?
  #26
Old 11-12-2013, 11:37 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Stud mount.
  #27
Old 11-12-2013, 12:08 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
FD, do you think there will be any chance of getting a weight on that bugger when all buttoned up (sans tranny)?
  #28
Old 11-12-2013, 05:08 PM
FireDodge's Avatar
FireDodge
If I remember, I can. My buddy does have a pretty large scale at the shop. More than likely we will take just the motor out of the truck and leave the tranny in it.
  #29
Old 11-13-2013, 09:54 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
http://www.harlandsharp.com/dodge_magnum.htm
Unless you got the heads modified with larger bolt holes you want the pedestal mount roller rockers. I had mine bored to 3/8" so I could run studs. Now if want you can buy the Mopar RR kit which has studs and guide plates. It uses the 5/16" hole and has studs that size. The nice thing about it is that it is a complete kit.
  #30
Old 11-25-2013, 12:16 PM
FireDodge's Avatar
FireDodge
Well, we swapped the motor this weekend.... but bad news, apparently in the process, the crank sensor was damaged. So now I have to find time and money to get the new sensor and do this all over again...
Quick Reply: FireDodge's 360 Build
