Little Do-dads to help my truck
  #51
Old 11-23-2014, 03:37 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
I think those are for a 4x4.
  #52
Old 11-23-2014, 06:28 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Originally Posted by tazmaniac
quick question Jimmythefan is your truck 2wd
No, mine is 4wd.
  #53
Old 11-30-2014, 02:06 PM
tazmaniac's Avatar
tazmaniac
tazmaniac is offline
As progress continues the 285/75/16 are about 8% taller do they make a easy speedo gear change and if not will this screw up the PCM
second question I have a friend that is a tire dealer and has a set of 285/75/17's that is slightly used what year dodge would work with my truck? as far as a 17 inch rim and i am assuming fitment should be an issue
  #54
Old 11-30-2014, 03:14 PM
HeyYou is offline
Check at Transmission Center for speedo gears. There is a chart just down from the top of the page that will tell you what gear you need. (30 tooth for you, I do believe)
  #55
Old 11-30-2014, 04:37 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Any 8 lug dodge wheel will fit your truck
  #56
Old 11-30-2014, 04:47 PM
HeyYou is offline
I think most Ford, and Chevy 8-lugs will fit as well. Ford had some nice aluminum slots for a while.....
  #57
Old 11-30-2014, 07:51 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Ford's only work before 2000. Round there they changed the pattern
  #58
Old 11-30-2014, 08:12 PM
tazmaniac's Avatar
tazmaniac
as usual thank you!I would assume the backspacing will be close on the off brands and will check it out, yes the 30 tooth would be correct
this is a great site for this type of usage
http://www.rimsntires.com/specspro.jsp
and actually using this site these rims will work
Wheel Fitment Check
Back
OEM tires: 245/75-16 (774x245mm). Big Hub. Bolt pattern: 8x165 (8x6.5). Offset: -10 to 10 mm. Tires up to 814x285mm (front). Rims up to 26x10.0" (front). Show what fits
Considerable fitment for 1996 Ram 2500: 7.0`` seems too narrow. Minimum recommended width is 7.5``. Other parameters are within OEM specs. See what else fits
Selected wheel:
Wheel Size Bolt Pattern (PCD) Offset (ET)
X
Is considerable for
Chevrolet: 1988-1998 2500 truck; 1990-1998 3500 truck; 2001-2007 Avalanche 2500; 1976-1986 C20 8 lug; 1997-up Express 8 lug; 1975-1987 K20; 1999-2007 K2500; 2002-2007 Silverado 1500 HD; 1999-2010 Silverado 2500; 1999-2010 Silverado 3500; 1991-up Suburban 2500; 1976-1986 Suburban C20 8 lug; 1987-1990 Suburban R20; 1992-1996 Van 2500; 1992-1996 Van 3500;
Dodge: 2002-up Ram 1500 8 lug; 1994-up Ram 2500; 1994-up Ram 3500; 2004-2010 Ram SRT-10; 1994-1999 Van 3500;
Ford: 2007-up E-150 van; 1968-up E-250 van; 1968-2006 E-350 van; 1968-1997 F-250; 1968-1998 F-350;
GMC: 1988-1998 2500 truck; 1990-1998 3500 truck; 1992-up Savana 2500 8 lug; 1992-up Savana 3500; 2002-2007 Sierra 1500 HD; 1999-2010 Sierra 2500; 1999-2010 Sierra 3500; 1991-up Suburban 2500; 1992-1996 Van 2500; 1992-1996 Van 3500; 2000-up Yukon 2500;
Hummer: 2003-2009 H2;
Nissan: 2012-up NV 1500 8 lug; 2012-up NV 2500 8 lug; 2012-up NV 3500 8 lug;
Ram: 2011-up 1500 8 lug; 2011-up 2500; 2011-up 3500;
  #59
Old 12-04-2014, 03:34 PM
ZipZap's Avatar
ZipZap
ZipZap is offline
Originally Posted by chromed95
tinted windows all the way around, ditch the granny running boards as stated, bigger tires and put a nice aluminum ProTech headache rack on that with some amber Hella LED's on it.
I asked my daughter for advice and she confirmed the list above.
She mentioned to change the color though too
Nice V10 from my point of view.
  #60
Old 12-25-2014, 08:19 PM
tazmaniac's Avatar
tazmaniac
Just a quick update on the Dodge..I removed the running boards it looks a lot better and I am debating the using tube running board or tube step..
2nd I scored 2008 dodge ram 17'' rims 150$ and found a set of 285/70/17s Cooper Discovery with about 8/32 left for 50.00, maybe last the summer and cheap enough to use for size just in case i don't like them that tall or a possible 4.10 gear?
3rd. purchasing electric tow mirrors (black) Ebay 165.00
4th. K&N air Filter
5th. 2" leveling coil kit, and 1.5" Add-a-leaf
yet to come window tint and Tonneau Cover and still deciding on exhaust
I will get a pic asap when I get the leveling kit installed
One other thing a buddy of mine gave me a mopar performance PCM from his 95 V10 to try
Quick Reply: Little Do-dads to help my truck
