Ball Joint Replacement Tool Rental Tip
Old 07-01-2015, 10:13 PM
DPR250R's Avatar
DPR250R
DPR250R is offline
Default Ball Joint Replacement Tool Rental Tip
Posting this in the hopes it helps spare someone the headache I went through.
When you replace your ball joints and rent the service kit... get the 23 piece set from Advance Auto. It includes a couple special fittings that make the job a breeze. I started with the kit from Auto Zone and was stuck when I went to install the upper joint. When installing the upper joint, using the angled cup that comes with the Advance Auto kit makes installing it a snap.
http://shop.advanceautoparts.com/p/p...8617/9150043-P
Old 07-01-2015, 10:48 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
For getting them out. Get your biggest BFH and smack the side of the axle where the ball joint is really hard after applying a lot of tension to the press.
Quick Reply: Ball Joint Replacement Tool Rental Tip
