Best headers?
i just went on summits website and these look just like mine http://www.summitracing.com/parts/su...iew/make/dodge
Best headers?
Trending Topics
LT's will give a little better performance gains (better scavenge), but these are sized for the 5.9 and are theoretically a little large (tube size) for the 5.2... not that I've seen a problem, and the more complimentary mod's I do, the less an issue that is.
They're a tight fit on the 4x4, but fit fine on 4x2... other than having to also change the Y-Pipe, they are a direct bolt up... it will push the cat back and you'll need an extension cable for the down stream O2 sensor (if you choose to keep the cat)... Use the plug saver trick if deleting the cat.
