wont start
RE: wont start
i was just recently fooling around under my hood and had a similar problem arise, it turned out to be a sensor or something on the drivers side at the back of the motor, it had just come un plugged a little bit, it is about an inch and a 1/4 wide and mine is gray, maybe check that sucker out
RE: wont start
you have to do the basic troubleshooting for no start, you need to find out what you dont have.
you need:
Spark
Fuel
Air
1. Air: is always easy, you always get air and if you dont have enough you will run rough or cough out
2. fuel: check for pressure or use a steth to listen to the injectors for clicking sounds to see if the open and close
3. spark: an inline spark checker (cheap from harbor freight) is a good way to see if you got spark, no spark? most likely a sensor problem like the : CrankPS, CamPS, and other stuff that falls under the spark category
hope this helps...
you need:
Spark
Fuel
Air
hope this helps...
RE: wont start
lots of electrical connections to check.
3 around top of TB. iac on rear, tps on drivers side, map on front.
injectors
alternator connection next to drivers side valve cover
a couple of grounds on power steering bracket. (not connected causes 'no bus')
intake air sensor on top pass. side of manifold.
temp sensor on front of manifold.
coil stuff.
distributor cap seated, rotor on ?, plug wires. coil wire.
injectors
coil stuff.
RE: wont start
When you say the fuel pump is not coming on. How did you check it? By ear or gauge?You canput a jumper across the leads where the relay plugs in to see if the pump fires up.Also check to make sure that the injectors are hooked up in the right order, and double check one more time forground straps hanging loose around the back of the motor and firewall. Did you disconnect the batteryground during the whole fix?
Trending Topics
RE: wont start
Ok here it is the rest of the story......
I checked all grounds there were no grounds on the back of the motor that I had removed. I called the local dealer and the mechanic said I have missed a ground and said try the back of the motor. I was slightly agitated as I knew I did not take anything off of the back end of the motor so just to prove to myself I was right I got up in there and I was right no ground but I did find the problem. When I bolted the manifold down a wire had gotten pinched in the last bolt on the drivers side and was grounded out. a twist of the bolt removed wire retorqued bolt and fired right off.
I let it warm up shut it down drained oil and as I am laying on the ground I slid the pan out only for a sales man to come up and trip on the oil spilling everything right there in the car port I was so pissed. Then the guy ran off. So out to the store for a bag of cat litter and a rental pressure washer. While pressure washing I am not sure how this happened but the glass in the front of my cap got broken so thats another $170 so in short this whole project has not saved me any money at all when you count what my time was worth. But I wouldnt let anyone else do it for me either.
Btw no more pinging I guess the first aluminum plenum plate was defective I did get a new one for free and since it was free I figure its not so bad.
