Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen How to Put Truck in 4WD
Step by step instructions for the do-it-yourself repairs.
Browse all: 4WD
How to put it in 4 wheel drive..
I know it sounds queer I am asking this...but when I bought my truck it didn't come up with an instructional manual. Anyways, when I am changing the different gears in the front differential, should I put the truck in neutral or in park. A few times when I was changing the floor shifter to various positions, it would make a very loud grinding noise because I had it in Park. Am I safe to play with the floor shifter if the transmission is in Neutral??
I have a 2001 dodge ram 2500 5.9 cummins and it seems i have tried all these ways of shifting into 4 wheel drive and ill get an occasional grind but other than that she works good, how bad is this to the tranfer and or tranny i thought i would ask cuz dodge isnt known for its amazing tranny thanks
2H to 4H or 4H to 2H
Shift while moving at any legal speed. The shift will be easier if you momentarily release the accelerator pedal. Apply a constant force while shifting the transfer case lever. 4H is to be used for traction when driving in rain, snow, mud or sand or when driving off-road. Never drive in 4H on dry paved roads.
Note: During cold weather (below 30F.) it may be more difficult to shift the transfer case while the vehicle is moving. If so, stop the vehicle and shift. Move the vehicle forward or backward to complete positive engagement of the gears.
4H to 4L or 4L to 4H
Slow the vehicle to under 3mph shift an automatic transmission to N (Neutral) or depress the clutch on a manual transmission. Shift the transfer case lever to the right and pull firmly down to 4L. Do not pause in transfer case N (Neutral)
Note: Pausing in transfer case N (Neutral) in vehicles equipped with an automatic transmission may require shutting the engine off to avoid gear clash while completing the shift.
Do not attempt to shift to or from 4L while transmission is in gear or clutch is engaged.
My old man swore the truck had to be turned off to go into 4lo, when I did it with the engine running in neutral he of course said that it was because I didn't care what I broke haha.
But yes it can be shifted with the engine running most of the time, I have found like stated before that a little movent of the vehicle helps, (I ike to shift on a hill so that if I feel it not fully engage I can let off the brake a little and help it) sometimes though mine will just refuse to shift into lo with the engine running so I turn it off and complete my shift
Grrrls do it, too!
lmao i feel so UNCOOL doing that for real around people.
i try and make up a technical term when i have a girl in the truck and she asks Why did u have to do that?
i have said things such as....
Well you see, the syncronizers in the transfer case in this year truck dont operate correctly on a Low to High gear ratio shift, causing a lot of slippage into final drive and affects my crawl ratio....
blabbing i kno but it works pretty good lmao
haha
haha
