Old 08-06-2015, 07:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
Replacing crank position sensor...how?
Old 10-22-2007, 08:54 PM
OlsenG_360's Avatar
OlsenG_360
OlsenG_360 is offline
Default Replacing crank position sensor...how?
I need to replace my crank position sensor in my 97 ram 1500 4x4. With a flashlight i can see it from underneath or through the wheel well (barely). But I certainly can't reach it from either of those places, unless i was to drop off the exhaust Y pipe. What's the best way to go about changing it? Those with experience, please step up.
thanks in advance
Old 10-22-2007, 08:57 PM
dillonjm's Avatar
dillonjm
dillonjm is offline
Default RE: Replacing crank position sensor...how?
Come in from the top of the engine. Its a PITA but I found that coming at it from above is the easiest way. You won't be able to see it, but you can feel it if you slide your hand in between the engine and firewall. The first time I messed with mine I had a lot of trouble, but now that I have figured out exactly which angles to come at it from it goes much easier.
Old 10-22-2007, 09:02 PM
OlsenG_360's Avatar
OlsenG_360
crap. i hate working blind
happen to know what size the 2 bolts are that hold it in?
Old 10-22-2007, 11:05 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
your best bet is to lay across the motor from the front... that way you can get your right hand on one side & left on the other.
Old 10-23-2007, 12:15 AM
OlsenG_360's Avatar
OlsenG_360
ended up being a 1/4 inch hex bit for those bolts.
and i'm confident in saying...if i didn't have my clutch fan removed already, this project would be a real b*tch. the position i found that i could work from was standing on top of the front sway bar in like a half-fetal position with my left hand around the back of the passenger side exhaust manifold and right hand down the back of the motor just to the drivers side of the trans stick tube.
1/4" hex bit, several different length extensions, and a swivel joint all on a 3/8 drive ratchet is what needed for tools.
p.s. i didn't exactly "replace" the sensor, i slotted the mounting bracket holesabout 3/8" and reinstalled. so far the butt-dyno definitely approves of this mod[sm=yeahsmile.gif]we'll see how mileage is affected
http://www.axcessmypics.com/photos/p...b1c548e8be.3g2 (a quick camera phone vid, looks like 0-60 is between 8 and 9 seconds, actually maybe even a little quicker since my speedo hasn't been calibrated for the 285/75/16's, with a little tirespin thrown in there wheni went overa bump)
Old 10-23-2007, 08:57 PM
bill022572's Avatar
bill022572
bill022572 is offline
for what it's worth : I read somewhere that the easiest way to access the crank sensor is to remove the passenger side inner plastic fenderwell. Never tried it - but makes sense. Maybe someone who has done it may know better. Sorry if this would have helped you if I had been on here earlier but maybe just an FYI for someone else.
Old 10-24-2007, 10:59 AM
OlsenG_360's Avatar
OlsenG_360
i think that's the easiest way for the dakota/durango guys to access it, because their motors aren't tucked so far back under the firewall.
Quick Reply: Replacing crank position sensor...how?
