what should be my idle RPM?
Old 10-31-2007, 09:26 PM
specialist484's Avatar
specialist484
specialist484 is offline
Default what should be my idle RPM?
I have a 01 Dodge Ram 5.9L 1500. I try to keep it in good condition and keep my maintainence schedule. I was wondering what my RPM's should be at when Im in park? I get around 500 at idle.
Old 10-31-2007, 09:32 PM
XXL 1500's Avatar
XXL 1500
XXL 1500 is offline
Default RE: what should be my idle RPM?
500 at idle is excellent!
means you are holding good vacuum and good ignitition and fuel delivery
about 750+ is starting to look bad... means the engine HAS to hold up speed to keep truck from missing or
running rough
Old 10-31-2007, 11:30 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
So what does it mean when you're at 600 RPM with a quiver in the tach needle?
Old 11-01-2007, 02:33 PM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
... is the 500 RPM when warm or cold? Obviously I get a better idle when the engine is up to temp than when I first start in park. I assume your refering to warm?
Old 11-01-2007, 02:38 PM
specialist484
Yeah, warm and after a minute at cold start up. Thats good to hear. Thanks
Old 11-01-2007, 07:55 PM
XXL 1500's Avatar
XXL 1500
XXL 1500 is offline
ORIGINAL: aim4squirrels
how much does it fluctuate?
could be just a cluster problem
nothing bad
Old 11-01-2007, 08:01 PM
aim4squirrels
Not even to the next 100 line on the tach, it just jiggles a little above 600 then falls back down about 2 times per second. It's pretty rhythmical. Might be a result of advancing the crank sensor. I'm not going to worry too much unless it's something to throw up an alarm about.
I just pretend it's really wanting to get a good jump off the line.
Quick Reply: what should be my idle RPM?
