transmission problems, overfull fluid?
RE: transmission problems, overfull fluid?
Some used to say to use Dexron, but Chrysler has since superseeded that and directs all to use ATF+4. I think if you switch from Dexron to ATF, you might have to have a full system flush so you don't have mixed fluids. ATF+4 is a better fluid then Dexron.
