360 plenum gasket leak question
I have read several posts about the gasket issue. I definitely need to investigate mine further since my oil is dissappearing as fast as I can add it.
My question is does this leak also affect performance and gas mileage? I am lucky if I can get 5 MPG downhill with the wind in OD.
Truck is 2500 stock other than 33's.
RE: 360 plenum gasket leak question
Since you are waiting for warmer weather to fix the plenum, do a search in the forum for the Hughes or APS billet plenum kits. Both work great from what I have heard. They replace the stamped steel plenum with a billte aluminum one. The plenum leak is caused by the stamped steel and the aluminum manifold expanding and contracting at different rates during engiine warmup and cool down. Just replacing the gasket still leaves you open to encountering this issue again in the future.
By replacing the plenum and gasket at the same time you eliminate the expansion issue, thereby eliminating the need to fix this problem again in the future. I have an APS plenum and would highly recommend either company to anybody that is going to fix their leaky plenum gasket.
Hi all,
I'm gearing up for a plenum upgrade myself..the job doesnt look too bad.. ( I have done alot of intake work on other models..ie...Chevy ) That being said.. this is my first Mopar...and my first experience with split gaskets...so..I have a question or two...
I know that you have to use some sealent in the corners where the intake, block and heads meet, do the gaskets that come with the Hughes kit overlap in this corner? lay over each other, then a bead laid on them in the corner? Or do they meet or have a small gap in that corner. I have seen some gaskets that had a "wave" pattern on the ends...( I think I saw oil pan gaskets for a Mopar that had this on the ends..??) if so.. is this so when the sealent is applied it fills this wave pattern? or is this cut off. All total newbie questions I know and apologise.. but honestly.. the only part of this whole project that scares me to death are the gaskets on this. Really dont want to have to tear this down again because I screwed up the corners on this intake. I'm also doing a 180 Tstat while I'm at it.
I would also like to know.. do you guys use any sealent on the block before placing the front and rear gaskets? If so.. I am assuming you are also usingsealent on the manifold in the areas where the front and rear gaskets are as well?or only in the corners? Any sealent being used on the new plenum gasket itself as well? And again.. I'm sure this is posted somewhere.. I have been searching.. but if you guys will put up with me....What sealents are you guys having good luck with on this repair? which is best for the corners, the front and rear gasket application? and the plenum gasket if sealent is used?
Thanks again for any replies!!!
ORIGINAL: Blaydrnnnr
Hi all,
Hi all,
The APS kit comes with very detailed instructions.I think it tells you to putthe tube gasket in the corners. I've yet to do mine butI have the APS kit here.You have to get new bolts as well.
Trending Topics
For those looking to save a little cash, you can get the intakebolts seperate from Hughes for $15. And get the upper gasket from Autozone (Felpro) for $9.99. The APS kit minus the bolts comes with the lower gasket and has the new plenum bolts.
I don't see what else APS or Hughes gives you for the $45 - $50 for the new bolts and gasket.
