1998 Ram 1500 Turn Signal stopped working
Old 02-25-2008, 03:07 PM
waltchess's Avatar
waltchess
waltchess is offline
Default 1998 Ram 1500 Turn Signal stopped working
The turn signal from my truck stopped working last week. Before it went out, I could hear weird noise under the dash while turning the signal. Now, it is completely dead, no indcators and no blinkers (both left and right). However, the emergency (4-way) is working fine. All the fuses checked out OK. There is only one flasher in the fuse box. This flasher is clicking when I turned on the 4-way switch (emergency). Is this the same flasher for the turn signal? Please help.
Old 02-25-2008, 07:28 PM
zique's Avatar
zique
zique is offline
Default RE: 1998 Ram 1500 Turn Signal stopped working
I'd be interested to hear the outcome on this. It sounds like your flasher is dead. I'm having a similar problem, but it only occurs when I use my right turn signal. I'm just not quite sure what to tell you.
Old 02-25-2008, 07:33 PM
charlie1935's Avatar
charlie1935
charlie1935 is offline
There is separate flashers for tur signals and hazard lights.
Zique, check and see if one of your right side bulbs is burned out. I have had that cause what you describe.
Old 02-26-2008, 03:13 PM
zique's Avatar
zique
zique is offline
ORIGINAL: charlie1935
Thanks for the tip. That was the first thing I checked though. The thing that is wiggin' me out is that the backup lights flash w/ the right flasher as well, but I've already verified that there aren't any crossed wires.
Old 02-26-2008, 03:21 PM
BostonRamGuy's Avatar
BostonRamGuy
BostonRamGuy is offline
Did you try a new flasher? Its like a 6 dollar fix.
Quick Reply: 1998 Ram 1500 Turn Signal stopped working
