Transmission overheating - dodge newbi Q
#21
What Arde said.
Here is a link to get rid of the check valve for good.
https://dodgeforum.com/forum/2nd-gen-ram-tech/247919-daves-8-00-or-less-tranny-check-ball-delete.html
Remember you cannot run just an auxiliary cooler by itself if you live in a very cold climate.
The transmission has to get to a certain temperature or the computer will not let tranny shift into over drive.
To cold of fluid is just as bad as to hot as stated earlier.
Run fluid thru the aux cooler first then thru the rad cooler, rad cooler helps maintain the proper temp.
Dave
Dave
