Old 08-06-2015, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
reset check engine light
Old 03-23-2008, 10:08 AM
owens2500's Avatar
owens2500
owens2500 is offline
Default reset check engine light
is there any way i can reset my check engine light?
Old 03-23-2008, 10:59 AM
wvjefo's Avatar
wvjefo
wvjefo is offline
Default RE: reset check engine light
Owens
Go to Auto Zone or Advanced. They can check the code & reset the light. FREE
Jeff
Old 03-23-2008, 11:23 AM
RM_Indy's Avatar
RM_Indy
RM_Indy is offline
Disconnect the negative cable from the battery. Turn the ignition to on for 10 seconds. turn off, reconnect the negative cable. If it comes back you still have an issue
Old 03-23-2008, 11:45 AM
SST2713's Avatar
SST2713
SST2713 is offline
Yeah, either the negative cable trick or an OBD II scanner from auto zone. I had a similar problem when I kept trying to pull the negative off of my battery, reset it, then it would come back on within a couple hours of driving it. So i got the code and it was "Cylinder 5 misfire" So i spent a few bucks and got new spark plugs. It could be as simple as that. Also, check your gas cap. That also sets of you check engine light.
Old 03-23-2008, 07:08 PM
owens2500's Avatar
owens2500
its showing PO304? u think spark plugs would fix this prob?
Old 03-23-2008, 07:33 PM
Ramsrush's Avatar
Ramsrush
Ramsrush is offline
PO304 is acyl.#4 misfire.Welcome to the forum.One tip,add the year,engine,etc. to question or to your profile. Good luck.
Old 03-23-2008, 07:35 PM
owens2500's Avatar
owens2500
its a 1997 2500 5.9 360 think new plugs would fix this?
Old 03-23-2008, 07:44 PM
Ramsrush's Avatar
Ramsrush
Ramsrush is offline
How old are the plugs and what kind are they?
Old 03-23-2008, 07:54 PM
owens2500's Avatar
owens2500
idk i just got the truck last sunday the guy said he just put new plugs and wires but they dont look new i dont kno what kind they r but i reset the code then it will drive fine for a while then it will come back on and do the same code so i was goin to change them again if u think it will fix the prob
Old 03-23-2008, 07:58 PM
wvjefo's Avatar
wvjefo
wvjefo is offline
When you do the plugs be careful how you run your wires. From the pros here if youdo it wrong & you will get a misfire.
Jeff
Quick Reply: reset check engine light
